KathrynK
Jul 24, 2020Aspirant
Temporarily disable 5 Ghz for Weather Station
AX4200 RBK752 Orbi Mesh Please HOW TO for Dummies How do I Temporarily disable 5 Ghz on my Orbi Mesh AX4200-RBK752 for Ambien Weather Station WS2902A
KathrynK
How do I reduce the power levels?
Jul 24, 2020Guru - Experienced User
You can actually just disable the wireless ssid broadcast for the 5ghz. It doesn't shut down the 5ghz but makes it more like a phone and the weather station will connect to the 2.4ghz.
Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5ghz.
You also need to make sure the phone that you use for setup is on the 2.4ghz during the setup process. You might have to disconnect reconnect to get it to associate with the 2.4ghz.
- KathrynKJul 24, 2020Aspirant
Where do I find this?
"Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5gh"
