BurschF
Jan 31, 2023Follower
temporarily disable 5ghz wifi to connect 2.4ghz devices at RBK852
Hello, I have a RBK852 with router and satelite installed. I am facing the issue with some 2.4ghz devices that I can't connect them to my wifi due to the 5ghz. Is there a way to temporarily disable t...
Feb 01, 2023Guru - Experienced User
You can't disable 5Ghz nor separate SSIDs on any Orbi AX System.
So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF ALL RBS temporarily. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Be sure that 20/40 MHz Coexistence enabled.
BurschF wrote:
Hello, I have a RBK852 with router and satelite installed. I am facing the issue with some 2.4ghz devices that I can't connect them to my wifi due to the 5ghz. Is there a way to temporarily disable the 5ghz to connect devices? I connect to the router and under wifi there are no options to toggle this on or off...... clearly a feature missing . Thanks in advance for your help and advice 🙂
