hshiau
Nov 29, 2021Aspirant
Terrible wifi speed on Orbi RB750 + 2 satellites
I have an Orbi RB753 setup with an RBR750 (firmware V4.6.5.14_2.0.54) and 2 RBS750's on the same firmware version. I also have a Cisco VPN router connected to the Orbi providing VPN services to a wo...
- Nov 29, 2021
And this is with the wireless device connected to the RBR and the RBS turned off?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Be sure that WMM is enabled. Also try setting CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
What is the connection rate seen on the Mac if you press the OPT and then right click on the wifi icon on the top tool bar?
And to be sure that wired speed connected at the RBR is to spec?
Nov 29, 2021Guru - Experienced User
Is the Orbi system in router or AP mode? If you have a router already in line, it's best to use the Orbi system in AP mode.
What is the brand and mfr of the wifi adapter in the laptop?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Have you tried turning OFF the RBS and placing the laptop in same room with the RBR and wirelessly connect to check speedTry enabling
Be sure WMM is enabled. Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR.
hshiau
Spectrum is my service provider. The modem is a Hitron Technologies E31N2V1.
The Orbi is in router mode. The modem does not provide wifi but the downstream Cisco router does.
I don't know the mfr of the wifi card but it's a Macbook Pro. I'm getting similar speeds on my iPhone.
The house is 6250 sq ft (yes big) and the satellites are both more than 30 ft away.
- FURRYe38Nov 29, 2021Guru - Experienced User
What is the model # of the Cisco router in front of the RBR?
It's not recommended to have two routers on the same line. Can cause problem such as your seeing. Try the RBR in AP mode with the Cisco router. Be sure that any wifi radios on the Cisco router are fully disabled.
