migsta
Apr 02, 2020Apprentice
The PAIN with Orib AX (RBK853)
Regardless of what anybody says, there is something really WRONG with Orbi AX. I just got my entire RBK853 system RMA'd and I'm in the same boat with the system being entirely unstable. What I s...
Apr 02, 2020Guru - Experienced User
What version of FW is the RBR and RBS using?
What is the mfr and model# of the main host router your using when you have the Orbi in AP mode?
Must be something going on as I and others have not had problems getting RBS connected.
I can do a remote or same room sync with RBS to the RBR and they get connected. Router and AP mode. Mines in AP mode currently.
After the RBS is configred and you hit the sync button on the RBR first then the RBS 2nd, give a couple of minutes before the RBS should get a BLUE front LED then eventually go OFF. I use a web browser to monitor the status on the RBRs web page. It eventually appears for me there and then go turn on the 2nd RBS and do the same process.
I don't use the Orbi app to setup the RBR or RBS.
migsta
Latest firmware. But I have only always hit the sync button on satellite and not router. So, maybe I am doing that part wrong. Either way, they are online now but super unstable with respect to how the iOS app is in a constant state between connecting to Orbi and seeing or not seeing the satellites online. And why would putting Orbi in AP mode suddenly cause it to lose the satellites, they don’t come online. I managed to get them online in AP mode but Orbi behaves the same with the app being accessible or not and the app network diagram regularly going between 2 and 0 satellites.
- FURRYe38Apr 02, 2020Guru - Experienced User
Ok, ya, you have to hit the sync button ON the RBR first then the button on the RBS. Both will sync wirelessly.
If you want them connecteded via ethernet, then connect the LAN cable after they are synced wirelessly. However there is a bug in AP mode with RBS ethernet connected to a RBR using a switch. They don't appear in the RBRs web page. They do appear in you don't use a switch. This is only in AP mode.
What is the distance between the router and satellite(s)?
- migstaApr 02, 2020ApprenticeRouter is in basement, no choice. One satellite on main floor and other one on top floor. I tried just the router and the router with one and both satellites spread out in different configs. The worst part is the cameras which do not connect outdoors and the indoor one is not viewable from extreme pixelation, only with Orbi AX. I also messed with channels, short preamble and 2347 RTS/CTS but same issue with all cameras.
No way to run a LAN cable from the basement up to the main floor to place the RBR there. Basement is not great places for any kind of wifi router. Maybe one issue your having with your system. You might check some local electical or eletronics shops to see if someone can help you run a LAN cable in existing walls to up on a main floor at some point.
what are the distances between the RBR and RBS?
