Solarflor
Jul 03, 2024Aspirant
The satellites of my Orbi RBR750 lose connection
Hello, Suddenly, the satellites of the Orbi RBR750 system disconnect and do not automatically reconnect. The reconnection occurs after bringing them much closer to the router and turning them back o...
- Jul 11, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 03, 2024Guru - Experienced User
Does the front LED on the RBR turn PINK when this happens?
Using Dynamic or Static AP mode configuration on the RBR?
What is the Mfr and model# of the Internet Service Providers modem/ONT or router that the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
