Solarflor
Jul 03, 2024Aspirant
The satellites of my Orbi RBR750 lose connection
Hello, Suddenly, the satellites of the Orbi RBR750 system disconnect and do not automatically reconnect. The reconnection occurs after bringing them much closer to the router and turning them back o...
- Jul 11, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 09, 2024Guru - Experienced User
Any progress on this?
Solarflor wrote:
Hello,
Suddenly, the satellites of the Orbi RBR750 system disconnect and do not automatically reconnect. The reconnection occurs after bringing them much closer to the router and turning them back on.
The router has firmware version 7.2.6.31
The 4 RBS750 satellites have the same version
I also have an RBS760 satellite 6.3.8.5 and it's the only one that sometimes automatically reconnects.
The system worked well until a few weeks ago but now it has become unmanageable.
The system is in AP mode.
Can you help me?
Thank you
Solarflor
Jul 10, 2024Aspirant
Hello,
thanks for your support and your reccomandations.
I hope to have solved the problem by performing a factory reset and setup from scratch.
To be honest I repeated it several times but the one that seems to work was when I included all satellites, one per time, having the system in Router mode and only at the end, when all satellites were included, I switched to AP mode.
Another action I did was to exclude the RBS760 satellite as I read somewhere that it was not fully compatible with RBR750 router.
The system is working since last Sunday so let's cross the fingers 😂
- FURRYe38Jul 11, 2024Guru - Experienced User
Enjoy. 📡- SolarflorJul 27, 2024Aspirant
Hello FURRYe38,
Unfortunately, the stable conditions lasted only a few days, and the RBR750 router (re)started losing connection with the satellites again. The only way to restore the connection is to power off one of the satellites and then power it back on.
At this point, all connections are reestablished.
I will now try to answer the questions you initially asked me.
Does the front LED on the RBR turn PINK when this happens? NO
Using Dynamic or Static AP mode configuration on the RBR? Dynamic
What is the Mfr and model# of the Internet Service Providers modem/ONT or router that the NG router is connected too? FRITZ!Box Fon WLAN 7360
Does this happen with the RBS turned OFF? No, RBS are on but not connected to RBR
Does this happen with both wireless and wired devices? I have only wireless devices connected to RBS
What channel configurations are currently set on the router? Please see the picture belowHas a factory reset and setup from scratch been performed since last FW update? Yes, it worked well for a will but now the problem occured again.
Thanks for your support
- FURRYe38Jul 27, 2024Guru - Experienced User
Try setting a static IP address configuration on the RBR for AP mode using this process in the PDF:
Also try setting a IP address reservation for the RBS on the host router as well.
