j_p_m's avatar
j_p_m
The satellites were randomly switching from router connection to daisy chain
I upgraded… but have had to rollback to 4.6.14.3
The satellites were randomly switching from router connection to daisy chain configuration, each time the blue light coming on for a few minutes at a time. This was happening frequently and quite annoying in a dark room. Downgraded to 4.6.14.3 and no such issue. Am I the only one?
  • FURRYe38's avatar
    Apparently.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected. Even thought worked on prior FW, there were improvements to wifi so RBS may need placement adjusting...
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? Highly recommended if problems are seen.
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • j_p_m's avatar
      j_p_m
      Thanks. I haven’t performed a factory reset yet. I accept there may have been improvements that mean the satellites can switch from router to daisy chain - and this could have been occurring seamlessly in the background previously - the issue is now when this happens, the blue light will turn and stay on for a few minutes - is this normal or is it a feature / issue of this firmware update?
      • FURRYe38's avatar
        LED is normal behavior if the RBS seem to be transitioning back and forth. However placement and distance between the RBR and each RBS is important and maybe a cause of the transitioning. I've not seen this with my 850 series with the v7 FW loaded.
