michsu's avatar
michsu
Apprentice
Jul 18, 2023
There's a problem with Orbi for many years now
There's a problem with Orbi for many years now; The way I do it is I connect the router to a Kasa and tell it to reset every day at 4am (or whenever you don't use it); That way, it seems to refresh the connections. Also, when coming home, many times I still have to disconnect the wifi connection on the IPhone and connect back again to get the full speed;
1 Reply
  • FURRYe38's avatar
    What model Orbi do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
