kewarken
May 13, 2022Aspirant
This happen very sudden like a week ago. Access was fine before.
This is pretty unacceptable support. My router is practically brand new and was very expensive and I'm already resetting it to lose all my settings? I have tenants and guests using this network so it...
May 15, 2022Guru - Experienced User
- jalshah05May 15, 2022Initiate
FURRYe38, I just saw that post. I really hope that they find a fix which does not require me to factory reset. I can wait till month end for them to push the fix otherwise I'll have to go factory reset and downgrade path.
- FURRYe38May 15, 2022Guru - Experienced User
You need to factory reset if you want immediate access.
- kewarkenMay 16, 2022Aspirant
The trust is gone now. If I'm going to need to reset my entire configuration because you pushed a bad firmware and can't provide any recovery path then I might as well buy a different system and set it up instead. Lucky I can still return mine.
Maybe next time think about opening up something like SSH access on your devices so that savvy users might have a chance to get in and salvage their configuration.
