BruceMartin's avatar
Feb 17, 2022
Tivo V125 error which means ORBI is blocking the connection between two tivos
RBR850 (not in choices above)
One Tivo can't watch another tivo because ORBI is blocking it (just recently started).  Anyone else?  What could be causing it (rebooting no help)?
  • Yes, Netgear does not keep the list of products updated on the drop down menu.(a constant source of annoyance for customers)
    Could you please post a link to the Tivo error message.  I searched tivo.com and did not find "V125" (or anything with the work "error").
    Which Tivo units are these, and how are they connected?
    This worked (for how long), and now an error message comes up?
    I have a Tivo Roameo and Tivo Mini connected to my Orbi RBR50 system. (To be precise, both the Tivo and Mini are connected to a PowerLine segment that is connected to the Orbi router. Perhaps they communicate between each other using only PowerLine?)
  • What Firmware version is currently loaded?
    • BruceMartin's avatar
      BruceMartin
      Guide
      Answers (thank you all):
      What Firmware version is currently loaded?  4.6.3.16
      Xfinity XB7 CGM4331COM
      Could you please post a link to the Tivo error message.  "V125"
      Response:  Tivo discontinued support for Tivo premiere boxes.  V125 means Tivo box not connected (which both are).
      Response: Both are premiere units and they are connected to my LAN by ethernet and wireless.
      Response: Over 5 years. First time error.  Rebooting modem, router, tivos, etc. doesn't work.
      I know it is the ORBI because the same time this started, my iphone can't maintain a connection to the the ORBI for internet (everything else fine).
      • CrimpOn's avatar
        CrimpOn
        Guru
        "Disconnected" is such an ambiguous term.
        • Do both Premier unit appear in the Orbi Attached Devices display with IP addresses?
        • Does the Attached Devices display show Access Control is "on" or "off"?
        • Does one Premier unit display an error regarding internet connection and the other not?
        • (Unfamiliar with this specific capability - Premier to Premier) Does it work in one direction but not the other?
        • Do the Premier units function correctly except for the unit to unit function?
