free4ed
Jun 26, 2024Aspirant
Trouble Connecting RBS750 Satellite to Router
I tried to connect my RBS750 satellite to my RBS750 router. Although the satellite’s ring light shows blue, the admin portal doesn't show the satellite. I did a factory reset on the satellite and syn...
Jul 01, 2024Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
