Tropical_Dave
Nov 05, 2022Follower
Trouble with Google home speakers on Orbi Ax1800 RBR350
I’m having issues with Google home speaker groups. Speakers drop in and out, some don’t play at all, when streaming music.
Have a Starlink satellite internet service with the Starlink set in bypass mode (no Starlink router) runnin straight into the Orbi. Speakers work fine on the Starlink if I use the Starlink router or if I use a different wifi router.
Dave
Dave
You might have better luck on the starlink site as not many users on here currently using it.
Try putting the starlink router back in and just disable its wifi. Then use the orbi in access point mode. See if that works.
It could be something to do with the starlink setup and issues when not using their router.
- iyangNETGEAR Expert
