webminster
Jun 14, 2021Luminary
Troubleshooting AX200 adapter no 11ax
How does one troubleshoot why my laptop, with AX200 Intel adapter, only appears to connect at 802.11a (according to Windows 10)? I updated the Intel drivers to the latest release (22.50.1), didn't h...
Jun 14, 2021Guru - Experienced User
Contact the Mfr of the adapter for help and information regdarding there adapter...
Try setting CTS values to 2347 from 64...
- webminsterJun 16, 2021Luminary
Got a referral to update drivers and use intel's best settings for the adapter, which I've done. Also updates the CTS as suggested. Not luck, still connected as 11a protocol.
Anyone else have a AX200 adapter that does get 11ax?
-Alan
- FURRYe38Jun 16, 2021Guru - Experienced User
You may have a faulty adapter that needs to be replaced. I'd try another or a different brand.
