tnine
Feb 01, 2022Aspirant
TrueNas time machine backups failing over Mesh Network only
Hello, I'm having a somewhat weird issue I could use some help with. I'm running TrueNas version TrueNAS-12.0-U7. I'm using an SMB "Mutli-protocol AFP/SMB Shares" as a time machine backup. When I ha...
- Feb 02, 2022
You can give this try as see if this helps any:
ekhalil
Feb 01, 2022Master
- Is Orbi operating in router or AP mode?
- What are the IP addresses assigned to the laptop and the FreeNAS?
