tnine
Feb 01, 2022Aspirant
TrueNas time machine backups failing over Mesh Network only
Hello, I'm having a somewhat weird issue I could use some help with. I'm running TrueNas version TrueNAS-12.0-U7. I'm using an SMB "Mutli-protocol AFP/SMB Shares" as a time machine backup. When I ha...
- Feb 02, 2022
You can give this try as see if this helps any:
tnine
Feb 02, 2022Aspirant
No, there is no router in front of the Orbi. In fact my ISP has assigned me a static IP. As a result my WAN has a static IP, and I've simply changed the addresable space on the LAN to a different class A subnet that requires less typing :)
