bulletinwbw
Oct 14, 2020Follower
Trying to put Orbi in AP mode, can't log into orbilogin
I just bought an Orbi RBR750 set from Costco and am trying to connect it to my AT&T BGW320 modem/router. After a lot of angst, I've realized I need to put the Orbi into AP mode. When I follow the ins...
Oct 14, 2020Guru - Experienced User
I would factory reset the RBR and setup the RBR from scratch, While disconnected from the host router.
Be sure to post about any Orbi AX questions, help or information over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
