Bmaddman
Dec 03, 2021Aspirant
Trying to set up smart plugs need 2.4 ghz phone is running on 5 ghz. Any advice?
I would like to just change the phone settings on the router and not have to change the router to 2.4 ghz only
CrimpOn
Dec 03, 2021Guru - Experienced User
The router 5G WiFi cannot be turned off.
What brand of smart plug is this? (I have about 10 different brands and all of the have connected to my old Orbi.)
Bmaddman
I'm trying to use home smart application and the bulbs are sunco. I too have about 20 different smart Devices no problems, I think I will have to try another type
