mrosen
Jan 06, 2021Tutor
Trying to setup RBK752
Model isn't listed. I'm trying to set this up but I'm having trouble connecting. I get this error page that's difficult to read. From what I can make out, I can't even sing the setting on my Samsung...
- Jan 07, 2021
Good to hear. Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Jan 07, 2021Guru - Experienced User
Try a wired PC and web browser pointed at 192.168.1.1
mrosen
Jan 07, 2021Tutor
FURRYe38 wrote:Try a wired PC and web browser pointed at 192.168.1.1
Thanks, I'll give that a try.
Does that cover the set up of the satellite as well?
- FURRYe38Jan 07, 2021Guru - Experienced User
Yes. Or you can add it later.
- mrosenJan 07, 2021Tutor
I reset the router today and ran setup again and got it working.
Thanks.
Enjoy. :smileywink:
