Roam83
Aug 08, 2023Follower
turn a router into a satelite
Hello! Is there a way i can turn the router to a satelite? I bought a pack of 2 ( RBK 752 Router and satelite), but then i needed two more set so instead buying two satelite, cause my dealirship d...
Aug 08, 2023Guru - Experienced User
Only router or AP mode is supported.
