rhystaylor's avatar
rhystaylor
Follower
May 28, 2023
Turn off 5ghz SSID
Hi,
I have read many articles about turning off the SSID on Netgear Orbi (RBR350 running firmware V4.4.1.29_3.10.80)
However I cannot identify this feature anyware in the menus.  Generally looking in Advanced>Advanced Setup>Wireless Settings.
Was this option removed in later firmware versions?  Or has it moved to a different place?
Thanks for any support in advance.
  • I wasn't aware you could do that on the AX routers. the older AC routers there was a work around for it but not an official ability.
    Why are you trying to turn it off?
  • Orbi AX systems have never had the ability to turn OFF any wifi radios.
    rhystaylor wrote:
    Hi,
