donawalt
Apr 24, 2024Hero - Experienced User
Turn off WMM advisable?
I was wondering - I have had WMM enabled on both my Orbi 850 and 960 for a long time. But now, with the 960 I am on a 2G Comcast plan. Since WMM is basically prioritizing video/audio over other traffic, and with a 2,5G pipe, should I turn off WMM? The other reason, I thought I have seen that with WMM off, WiFi performance improves - which is logical if audio/video is being prioritized higher.
Thoughts?
It's recommended to keep that enabled for 2.4Ghz devices. Though if your not really using 2.4Ghz, I suppose you could disable it. User option.
- donawaltHero - Experienced User
Hmm. I have smart plugs, a Ring doorbell, and Harmony Hubs for TV remotes that all use 2.4. So I guess I shouldn't....
EDIT: I forgot - NG doesn't let you have access to WMM in the 960 anyway...
Something to try, I can only see the Ring Door Bell maybe needing bandwidth. Hubs and devices that don't need much or lots of bandwidth wouldn't have a need for any WMM QoS processing as I presume some of these devices have intermittent usages or data flow.
