DoctorA's avatar
DoctorA
Luminary
Nov 06, 2019
Two RBK 853 systems with one RBR in AP and two RBS850
@Chuck_M, and others are reporting that RBR 50 is working fine wired in AP mode. I don't have RBK 53 components. I am considering  buying the second RBK 850 systems. The reason I paid extra (my wife doesn't know yet) for RBK 830 system is so that my kids don't complaint that we don't have Wifi 6 in few months after getting the latest laptops and smartphones. Also it looks like the RBK 830 is stronger and covers more square footage. Plus my 40 devices inside the home are connected in very stable way even though some of them receive weak signal bellow two floors.
Since I have a 7000sq ft area to take care of and have distant wifi devices in the back yard, I need at least 1 more satellite and probably two.
I called support to buy a second satellite and they said it is not available and even if I add another one it is not supported yet. I am just going to try it. What can go wrong?
  • FURRYe38's avatar
    Let us know how it does with a 2nd RBS. Hopefully it will connect and work. No sure if a 2nd will sync or the FW will even allow it. I presume it might. No idea. $1400 for two systems. Wow.
    Remember, 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Let us know how it turns out.
    • DoctorA's avatar
      DoctorA
      Luminary
       Do not forget that in addition to 3 level 7000 sq ft home I also have a 2500 sq ft area in the back yard that need Wifi. You are correct, it is a lot of money. If one RBS 850 was available I would just try only one if it can cover both backyard and first floor placed near window.
      I need more signal on the 1st floor and coverage for the backyard and pool 70 feet away.
      Anyway, I am planining to connect the second system with Ethernet wire like my excisting backhaul. I have two options.
      I have one Ethernet jack on the left side of the middle level connected to the RBR 850 upstairs on the 3rd floor.
      I have another Ethernet jack on the right side of the 1st floor now connected to RBS 850 upstairs.
      I can put one new satellite near 2nd floor balcony or balcony ceiling for outdoor coverage and one on the first floor inside both connected to my exsisting RBS upstairs on the right. Is this called daisy chaining? is this allowed?
      Another option is to connect one new satellite to the exsisting router upstairs and install on the 2nd floor Ethernet jack near left window for the backyard/indoor coverage.
      Plus connect another new router in AP mode to the exsisting RBS 850 upstairs and install it next to the 1st floor right Ethernet jack.
      Thank you
      • FURRYe38's avatar
        Another suggestion would the RBSY model outdoor satellite. Hopefully NG will get this supported in the near future.
