306Orbi
Aug 21, 2022Star
TX Rate 1200 Orbi Wifi 6E
Hi There... I have a Newest Xfinity Modem (Wifi 6E) in Bridge Mode connected via the 10Gig port on the Xfinity Modem to the 10 Gig Port in my Orbit 963E Router. Orbi Login Speedtest shows Internet ...
306Orbi
Aug 21, 2022Star
Also under Wireless Setup - Wireless Settings - I have checked YES to 6Ghz Wireless Settings and see a SSID.
This SSID is not being broadcasted by Orbi... as I don't see it on my iPhone Max 13 or the M2 Mac Air.
Thanks.
Aug 21, 2022Guru - Experienced User
Did you set a new unique SSID name on the main WLAN settings? Try RBKE960 as a temporary name.
Try a factory reset and setup from scratch with a wired PC and web browser to set up the RBR. Turn OFF any RBS for now.
- 306OrbiAug 21, 2022Star
I just finished talking to Apple... The M2 Mac Air Can Connect at upto 9.6 Gigs Tx Rate (speed).
I think I need my Orbi router to broadcast the 6 Ghz SSID (wifi 6) and once I Grab that I will see the higher connection unto 9,6 Gigs
Reset will be a huge amount of work... so I will try to figure out how I can get it to broadcast Wifi 6...
Will let you know once I find success.
- Mikey94025Aug 21, 2022Hero
306Orbi wrote:I just finished talking to Apple... The M2 Mac Air Can Connect at upto 9.6 Gigs Tx Rate (speed).
Don't confuse link rate with what realistic wireless speeds you can experience. For example, for Wi-Fi 6 (on 5Ghz, not 6e on 5Ghz) this Google page shows that Macs over wireless still peak out at 700 Mbps max. You may get better with Wi-Fi 6e but I still don't think you'll see realistic speeds very close to your upstream provider max of 1400 Mbps.
