ae6dx00
Feb 05, 2021Guide
unable to access web interface or orbi app
I have remote access enabled on my Orbi. I can ping its IP address ands connect via VPN. but both thew web interface and app refuse to connect. Devices on the network are getting an internet connecti...
s3v3n
Jun 04, 2021Tutor
I have this exact issue occurring with my AX6000 units. For some odd reason, periodically I will not be able to access my system via the app "issues connecting to #wifi' and the router GUI via 127.0.0.1 is unresponsive. Manual reset of the main router will correct the issue, but issue will occur again. A factory reset does not resolve permanently.
3x AX6000 running the latest firmware, new issue.
- FURRYe38Jun 05, 2021Guru - Experienced User
The RBRs web page is located at 192.168.1.1 by default no 127.0.0.1.
What FW version are you using?
3x AX6000 running the latest firmware, new issue.- s3v3nJun 05, 2021TutorBlah, I meant 192.168.1.1; not 127.0.0.1. Sorry for the mistake, late night.
Firmware is 3.2.18.1 on router and satellite units.
Network equipment is Netgear CM1100 modem aggregation linked to the AX6000 unit. DHCP is disabled on the router as I maintain a Pihole for the DHCP and DNS.
ISP is Comcast with gigabit, 1000/35- FURRYe38Jun 05, 2021Guru - Experienced User
Wonder if this problem still happens if LAG is disabled and you enable DHCP on the RBR instead of using PiHole?
Has a full power OFF of the ISP Modem and RBR for 30 seconds been performed since last update?
Any factory resets since?
