SKEN57
Dec 27, 2021Aspirant
Unable to cast via RBS750
I have recently switched over to an RBR750/RBS750 wifi 6 network. Previously had no issues casting to Chromecast or to Samsung TV. Now can't cast to either via the satelittes but can with just the ro...
Dec 27, 2021Guru - Experienced User
Try turning off AX for 2.4hz
CTS set to 2347
- SKEN57Dec 27, 2021Aspirant
Firmware is the very latest production version for the RBR750 4.6.5.14, tried with AX off and on, CTS set to 2347.
I have several (3) satellites, all set at optimum distance from the RBR750, over 30 feet to cover 3000 sq ft. I have 1Gbs Virgin Media cable, the provided router is as standard Hub4 and set to Cable Modem mode with latest firmware. This is only since I switched from an RBR/RBS50 setup and I had the latest firmware update. Connection straight to the router works if I turn off all satellites but signal strength not best.
