tomTWH
Oct 25, 2023Tutor
Unable to connect RBS850 to RBR750 network
Hi, I recently bought an extra satellite to add to an existing network (RBR750 router and 2 RBS750 satellites). It is an RBS850. According to the Netgear compability overview, it should be possible...
Oct 25, 2023Guru - Experienced User
What FW is on the RBR and I suppose you don't know what's on the RBS850? FW needs to be at same level between the RBR and RBS.
