dtay
Aug 26, 2020Luminary
Unable to login to Orbi satellites & and security is "none"?
This is a strange one. Two RBS units, both running the latest firmware, both on wired backhaul to the RBR and operating fine. Both have DHCP reservations (192.168.1.101 and 192.168.1.102) and ar...
Aug 26, 2020Guru - Experienced User
I have seen that before as well. I did power OFF the RBS for 30 seconds then back on then it seemed to collect the configuration from the RBR correctly.
dtay
Aug 27, 2020Luminary
This morning, I tried logging back on to one the RBS after rebooting and I was able to get in. But after clicking on the "connected devices" tab, I lost GUI access to the RBS. The RBS is still pinging and up.
I powered off that RBS and it's been over > 3 mins now yet the RBR status page still says that powered off RBS is still connected??? I know if I reboot the RBR, it will correctly reflect that the RBS is off.
Update: it looks like it takes about 10 minutes (after refreshing several times) before the RBR status page correctly shows that the RBS was disconnected/powered off.
- FURRYe38Aug 27, 2020Guru - Experienced User
Ya it take a while for the RBR status page to update.
