sbemb
Mar 15, 2020Follower
Unable to Make Client -> Server Connection On My AX5700 (RBR840) Network
I have a Windows client that needs to connect to a Linux sever to run an application on the server. Since setting up the Orbi AX5700 (RBR840) Network, I cannot get this to work anymore. I can confirm...
ekhalil
Mar 17, 2020Master
- Are you using firmware v3.2.10.11 in Orbi? Have you seen the same issue before this software? If you get it to work sometimes and then it disconnects, then it can be related to the connection-oriented session issue that is now reported in v.3.2.10.11. Please try to downgrade to v3.1.5.23 and see if you will keep seeing the same issue.
- What do you get if you run tracert 8.8.8.8 from the linux server?
