vnl
Mar 07, 2023Tutor
Unable to see any devices connected to the satellites
Hi all, Recently moved and started using a new ISP. The damn ISP uses their copper wired nonsense still. So have to use their router but have set up as a modem. I have my orbi as a router and satel...
Mar 08, 2023Guru - Experienced User
What ISP modem do you have?
Some are pretty junk.
You can try putting the ISP device back in router mode (disable its wifi) and then either put the netgear in access point mode or put the netgear into the ISP's DMZ.
vnl
Mar 08, 2023Tutor
I can try that for sure just that I wanted to take advantage of all the router functionalities of Orbi as a router. Seems more like a bug, no?
- plemansMar 08, 2023Guru - Experienced User
With the ISP device sure.
They're rarely updated and tend to be the cheapest possible made.
The orbi worked fine before? And once you introduce the ISP device, issues.
- vnlMar 09, 2023Tutor
The issue started with the new ISP (Virgin Media in the UK and their Hub 5 Router).
In the last place, I did not have to use the ISP's router. So it was all easy and perfectly working.
In this new place, I need to use their router, which is causing an issue. I will try and go back to using the ISP router as a router and disable wifi and check.
I still think it is Orbi's issue, as I do not see the devices connected to the satellites only.
- CrimpOnMar 09, 2023Guru - Experienced User
How is the satellite connected to the router? (WiFi?)
