Ericasjourney
Mar 21, 2023Aspirant
Unable to see Satellite AP
I have a recent RBR860 that replaced an aging Deco system. Since installing, the satellite has been rock solid in my home office that is detached from my house. This week however, it started constant...
- Mar 25, 2023
Thank you both for your assistance. At the end of the day, I unplugged all internet equipment in the house for like 10 min the reconnected one at a time. I also relocated the furtherst AP about 15' closer and is now as close as possible without sitting outside the MIL suite. After doing this, everything seems to have stabilized again and has been solid without a single drop or latency for a few days now (beyond the neighborhood power outage thanks to lack of notification from power company lol)
I do have an issue when I walk between buildings that I have to reconnect to the AP in that building for some reason but it's easy to do. Not sure if this is a setting in the system or just how the Orbi is but as soon as I'm out of range of one, I have to reconnect to the other. Inconvenient and didn't do this with my old Deco system but it's easy to adjust for.
Ericasjourney
So was the system working well before this security system was installed? Yes, worked seamlessly and FAST
Does this security system have wireless capabilities of it's own? All the different sensors (doors, motion, cams) connect wirelessly to the security hub. The hub is connected specifically to the ISP wifi and not the mesh.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Uncertain, the ISP equipment was provided by Suddenlink, now known as Optimum. It is an Altice branded equipment and I have no access to their stuff as they are a royal PITA.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended; I have no idea unfortunately how this is wired as the connection was already present in a new build. Builder was an idiot but as mentioned, I've had zero issues to date until just this week post install of the security system.
How many RBS are deployed? 1 main and 1 satellite
What is the size of your home? Sq Ft? ~2000 sq ft but two buildings. "A" is the approx location of the primary AP and "2" of the satellite in my home office. This is approximately ~50 ft and is about as close as I can possibly get short of running cables across the floor of my main home. Both APs are along outer walls of the buildings and "2" next to a window on top of the fridge there.
I have not rebooted the ISP or main router at this point in time, just the satellite 2x; once in it's original location closer to the door of the garage then again when relocating it into the kitchen of the office area where "2" is currently sitting.
Mar 21, 2023Guru - Experienced User
If the Orbi was working before the security system went in and not is experiencing problems and the security system is some wireless abilities, maybe the cause of what your seeing. Would be telling if you were to completely turn OFF this security system, as to not cause any alarms, and see if the Orbi worked again as before.
Might ask the mfr of this security system about it's wifi abilities, channels and frequencies used. If there are any similar channels used as on the Orbi system, try and move the channels far apart from each system as possible.
