MrBobert
Feb 04, 2025Aspirant
Unable to set up iinet (IP provider) PPPoE connection to NBN modem
Hi All, First note that my Orbi is actually a RBK753 which product type wasn't a pick option. I just got my NBN fibre modem (G-240G-P) connected and was wanting to connect my mesh router direct ...
- Feb 15, 2025
I did dig into more yesterday with success. The application keeps looping and will never find internet. i can only change rudimentary internet settings (pppoe,user name and password). My ISP wants me to specify the VLAN bridge to 2.
When the application stated endlessly cycling I logged onto my orbi router with my laptop. With the laptop I was offered more internet settings than the app gives. When I set the VLAN bridge up properly everything started working.
FURRYe38, thank you for taking the time to have a look at my issue
Feb 14, 2025Guru - Experienced User
Yes sometimes the ISP modem/ONT needs to be power cycled or rebooted to take effect of a new router connection.
Also make contact with the ISP as well for there help and support on there configuration.
MrBobert
Feb 15, 2025Aspirant
- FURRYe38Feb 15, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
