hTep
Jan 21, 2025Guide
Unable to setup a new Orbi RBR750 after hard reset
Hello Team, After a hard reset, I'm not able to set up a RBR750. To be more specific, my RBR is connected to an ISP bridge but Orbi router need to be configure. Impossible to set a password, I ...
Jan 21, 2025Guru - Experienced User
for the initial setup, just make sure your password is at lease:
10 character
1 special character
1 upper case letter
1 lower case letter
1 number
If that doesn't work, try a different browser.
hTep
Jan 21, 2025Guide
I did, even if there is no information on pre requisit.
Doesn’t work…
Unable to setup a rbr750 (600€) without internet connection.
Doesn’t work…
- hTepJan 21, 2025GuideOther question, regarding user experience. Where can I change langage?
- plemansJan 21, 2025Guru - Experienced User
did you try a different browser or device?
To change language, here's the guide for nighthawk. should be similar for orbi?
https://kb.netgear.com/24001/How-do-I-change-the-language-on-my-Nighthawk-router
- hTepJan 21, 2025GuideUnfortunately doesn’t work.
Thanks
- CrimpOnJan 21, 2025Guru - Experienced User
hTep wrote:
Other question, regarding user experience. Where can I change langage?On Orbi routers, there is a Pull Down menu in the upper right part of the web interface:
- hTepJan 21, 2025GuideHello, I’m on the setup (1st connexion) page. No pull down Menu, see my screenshot 🙂
