KManT
Jul 26, 2021Aspirant
Unable to unblock devices on RBR750 after FW update to v4.6.3.7
I installed the new FW 2 days ago when the app showed update available. Since then I can not unblock my daughter's 2 devices (iPad mini and MacBook Air). The status shows as paused in the App, then ...
KManT
Jul 29, 2021Aspirant
No, intend to do it on the weekend to minimize down time during the week.
Thanks
Thanks
Jul 29, 2021Guru - Experienced User
I recommend that when you factory reset the RBR and set it up from scratch. Set up minimal settings first. Don't enable Armor, Access Controls or SPC or Traffic Meter. Do a backup config to file here at this point. This will give you a base config file in case you need a reset and need back up and running quickly.
After you do this, then setup all the other features that you want. Make sure is working as you need too. Then do another backup configuration to file. Then you have a options config file in case a reset is needed later on.
I recommend setting a IP address reservation on the RBR for any devices that you use in the access controls and in the Orbi app to control block and unblocking of devices.
