Colin747
Feb 27, 2024Aspirant
Unable to update satellites RBS850
I have noticed that my RBR850 and satellites are out of sync. I am unable to even find the original firmware of the products and have tried factory resetting all devices. The satellites connect by rem...
Feb 27, 2024Guru - Experienced User
What happens if you ethernet connect the RBS to the back of the RBR? Do they then get a IP address from the RBR, and if so, can you log into the RBS using this IP address?
What FW version is on the RBR now? Remember what version had been loaded prior to it being updated?
RBS need to be updated first before the RBR is.
Colin747
So I have connected the RBS to the RBR using ethernet. On orbilogin, attached devices it says the satellite is now connected via wired, but still out of sync. On the firmware page it still says "service unreachable". I have tried accessing the satellite via IP on safari: "cant open the page because page's address isn't invalid".
Current firmware is V4.6.14.3_2.3.12. I have no clue what the original firmware was before.
- FURRYe38Feb 28, 2024Guru - Experienced User
What happens if you select the GENERATE button seen on the RBRs web page Under Advanced Tab/Advanced Settings/Wireless Settings
Then try to resync the RBS to the RBR using the Add Satellite feature on the RBRs web page?Can check this as well:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.1.250 for Orbi AC/192.168.10.250 for Orbi AX. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
