magnum454
Sep 18, 2024Aspirant
Unfortunately updated router firmware before satellite firmware, satellite will not connect
I updated the firmware on the router (RBR850) from 3.2.x.x to 7.2.6.31 (some version of 3.2). Now, my satellite (RBS850) will not connect due to a firmware mismatch. I have tried to rollback the fi...
- Sep 19, 2024
I was able to fix it by performing a 30-30-30 reset of the satellite. I had changed the SSID in the initial setup of the mesh system, and when I performed the firmware update of the router, the SSID of the router was reset to the default while the satellite still had the renamed SSID. The standard single push of the reset button on the satellite was not resetting the SSID back to the default.
magnum454
Sep 19, 2024Aspirant
Sep 19, 2024Guru - Experienced User
Be sure that next time, update all RBS FIRST, then the RBR lastly.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
