Ragutis
Feb 22, 2023Tutor
Unknown new 'satellite' shown
Hi I have the RBK853 WiFi 6 Mesh which has the 2 satellite, RBS850. Usually when I look at attached devices in the Orbi software I see the 2 RBS850 under the 'Connected Satellites' section and then ...
- Feb 25, 2023
Other posters historically have posted about the same issue, FR was the permanent resolution.
Feb 24, 2023Guru - Experienced User
Factory reset the RBR and RBS and setup from scratch.
Be sure FW is same on all RBS as what's loaded on the RBR.
