wap1
Aug 11, 2021Aspirant
Unknown wlan0 devices on 2.4 ghz Orbi network
On my RBR750 router with two wireless mesh satellites (Orbi RBK752 system), I occasionally see two devices connected to the 2.4 ghz wireless network, and they are both labeled “wlan0”. What are these?...
- Aug 12, 2021Solution was found on duplicate posting in another thread https://community.netgear.com/t5/Orbi/Unknown-wlan0-devices-on-2-4-ghz-Orbi-network/m-p/2126989/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtTOEdFMTJLUEFLWjZLfDIxMjY5ODl8U1VCU0NSSVBUSU9OU3xoSw#M124360
Thanks the the help!
wap1
Aug 12, 2021Aspirant
Aug 12, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
