MikeElmendorf
May 13, 2020Guide
Unstable/inconsistent speed on Orbi RBK 852 AX6000 after upgrade to Spectrum Gigabit
Hi, All - New member of the community here. I set up my new Orbi RBK 852 system (with two satellites) last Friday, replacing a series of Apple Airports I had been using for some time. I had ...
- May 13, 2020
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
What happens if you disable AX mode to test...
May 13, 2020Guru - Experienced User
Has the ISP modem and RBR been powered OFF for 1 minute then back ON with the modem then the RBR?
You should see near 900Mpbs speeds on a wired connection. Wireless, depending if you have AX support on your wireless devices and the design and speed support on those devices, I presume should need over 500Mpbs speeds. Most current AC mode supporting devices max out at around 400-500Mpbs wirelessly. Again depends on device design and support. Something to contact the Mfr about to see what they say.
- MikeElmendorfMay 13, 2020Guide
Thanks for the reply, Furry -
The Orbi firmware is V3.2.10.11_1.2.12.
The modem model is E31T2V1. I believe it is a Technicolor, based on what Spectrum has said, but it doesn't say much on the modem itself.
I have powered the modem and router off a number of times. I'm not sure every time was more than 1 minute, but at least some of those attempts were.
This is the modem: https://d15yx0mnc9teae.cloudfront.net/sites/default/files/Spectrum_D31_eMTA_Data_Sheet.pdf
- FURRYe38May 13, 2020Guru - Experienced User
Ok, just checking for router with the modem. No router here.
I would say Orbi is working well. Wireless speeds again will be based on enviroment, noise and device design and support.
IF your getting near 900Mpbs on the wire, it's working...I know mine does. Though to get near 900Mpbs on wireless, I usually have to connect up my ASUS GT-AX11000 wireless bridge and I do see good speeds there. Thats the only AX client I have currently. I believe my D-Link DWA-192 adapter seen near 900Mpbs as well.
I guess what I'm struggling to understand is why, with a much faster connection, I would be seeing speeds lower than my old 350 at any time when I really did not before. Also, the instability seems odd.
