MikeElmendorf
May 13, 2020Guide
Unstable/inconsistent speed on Orbi RBK 852 AX6000 after upgrade to Spectrum Gigabit
Hi, All - New member of the community here. I set up my new Orbi RBK 852 system (with two satellites) last Friday, replacing a series of Apple Airports I had been using for some time. I had ...
- May 13, 2020
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
What happens if you disable AX mode to test...
May 13, 2020Guru - Experienced User
Has the ISP modem and RBR been powered OFF for 1 minute then back ON with the modem then the RBR?
You should see near 900Mpbs speeds on a wired connection. Wireless, depending if you have AX support on your wireless devices and the design and speed support on those devices, I presume should need over 500Mpbs speeds. Most current AC mode supporting devices max out at around 400-500Mpbs wirelessly. Again depends on device design and support. Something to contact the Mfr about to see what they say.
MikeElmendorf
May 13, 2020Guide
Thanks for the reply, Furry -
The Orbi firmware is V3.2.10.11_1.2.12.
The modem model is E31T2V1. I believe it is a Technicolor, based on what Spectrum has said, but it doesn't say much on the modem itself.
I have powered the modem and router off a number of times. I'm not sure every time was more than 1 minute, but at least some of those attempts were.
