cv123's avatar
cv123
Guide
Aug 21, 2022
Update firmware from 4.6.8.2 rbs850
I cant get to the interface to update the firmware. I've tried to reset but it hasn't worked.   Any suggestions?
  • cv123's avatar
    cv123
    Aug 21, 2022
    The RBR was ok. It's the RBS.
    I has to power down the RBR, connect to the RBS with ethernet and reset. I was able to pull it up from 192.168.1.250.
    From there I could do the firmware update, but once up and running, I still can't connect to the RBS from the web for future updates.
    Is that something new?
