MiddKid
Mar 23, 2023Guide
Updated and working, but "failed"...do I care?
I have an RBR850 router with five satellites...two 850s and three 750s. Checked the firmware on my phone this morning and ran the update. After the update, the router said "Update failed" (but list...
Mar 23, 2023Guru - Experienced User
If the FW was applied thru the AU on the RBR or if you manually updated the system, RBS first, then RBR lastly, you should be fine.
You might power cycle OFF the ISP modem and RBR and RBS for 1 minute then back ON.
