John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three...
- Dec 16, 2025
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
Apr 19, 2025Guru - Experienced User
Someone else reported seeing this on there 750 series. How was the system updated? Manually or Auto update or Update ALL?
RBS should have been updated first manually then the RBR lastly.
John--B wrote:
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three devices are currently connected to the RBS750QV. Anyone know what is wrong?
- John--BApr 19, 2025Star
Updating was done manually with the satellites completed before the router.
- FURRYe38Apr 19, 2025Guru - Experienced User
Does this V appear the RBS web page itself?
Does this appear on the RBRs web page under the connected devices page?
Did you load the FW thru the RBS web page?
Which web browser did you use?
- CrimpOnApr 19, 2025Guru - Experienced User
The previous discussion was from March of this year:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBS750-amp-RBR750/m-p/2444019
Did not appear to be any resolution on that.
