John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three...
- Dec 16, 2025
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
John--B
May 21, 2025Star
I updated my system a couple of days ago with the same results. I' m now at v7.2.7.15, all appears to be working correctly but I still have a satellite which shows up as a model RBS750QV in the Orbi app along with the firmware failure notation under firmware update. I will leave it at this firmware level unless I find a new issue. Thanks for all of the suggestions!
- FURRYe38May 21, 2025Guru - Experienced User
Does the QV appear on the RBS web page if you log into the RBS web page there?
