John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three...
- Dec 16, 2025
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
John--B
May 21, 2025Star
The QV does not appear on the RBS web page. It only shows up on the firmware update page under “Model Name” and the Status says “Update failed”.
- FURRYe38May 21, 2025Guru - Experienced User
Thanks for confirming this.
And RBS is working normally otherwise?
- John--BMay 24, 2025Star
Yes, the satellite appears to be working correctly with no issues.
- FURRYe38May 24, 2025Guru - Experienced User
Ok, We've passed this on to NG for review so they know about it. I presume that if and when a new FW version appears, the QV issue may inhibit the RBS from being updated correctly. Hopefully NG will fix that.
