John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three...
- Dec 16, 2025
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
KnightWare
Dec 15, 2025Initiate
Same here RBS750QV update status failed. Checking for new firmware under 7.2.1.5 says nothing new. However, Net Gear site says it's 7.2.8.5 for the RBR750 and RBS750. I disabled auto update and downloaded/manually updated both satellite first, then the router. The router name reversed back to RBR750 and both updates successful (No update failure on RBS750.
Dec 15, 2025Guru - Experienced User
Glad to hear this and glad the RBS reverted back to corrected operation.
Enjoy. 📡
