John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three...
- Dec 16, 2025
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
John--B
Dec 16, 2025Star
Dec 16, 2025Guru - Experienced User
Good to hear. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
John--B wrote:I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
