Z42985
Oct 24, 2019Aspirant
Updating firmware - Service unreachable / No New Firmware Available but on 3.1.4.7
BTW: RBR850, RBS850, RBK852 is not in the model drop down. The Firmware update page says Service unreachable for RBR850 and for the RBS850 says No New Firmware Available but they are both on 3.1.4...
- Oct 25, 2019
You can't upload the ZIP archive. Unpack both (the RBR and RBS) version, and select the RBR850-V3.1.5.23_1.0.46-signed.chk resp. the RBS850-V3.1.5.23_1.0.46-signed.chk for the upload.
Lack of documentation ...
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
===... Netgear is humouring us here, there is currently no user manual available - put the new firmware first to the satellites.
PS. My non-native English heart does stuck reading "product's firmware" and "product's user manual" ... michaelkenward can you educate me? Thank you in advance!
Z42985
No luck, got this trying to upgrade the router with RBR850-V3.1.5.23_1.0.46.zip
"Firmware upgrade failed. Please check your file."
- schumakuOct 25, 2019Guru - Experienced User
PS. My non-native English heart does stuck reading "product's firmware" and "product's user manual" ... michaelkenward can you educate me? Thank you in advance!- Z42985Oct 27, 2019Aspirant
Ah, of course, should have known better.
So it still says "Service unreachable" on the firmware update page for the router.
I also couldn't get the sattellite to reconnect after upgrading both of their firmware until I factory defaulted it.
