jazzboypro
Jul 28, 2022Aspirant
Updating multiple hosts with no-ip
Hello all, Juste purchase the Orbi AX6000. I have setup the dynamic DNS with no-ip and it works fine. The problem is that you can only add 1 host to update and i have more than 1. Is there a way aro...
Jul 28, 2022Guru - Experienced User
You can enter in manual custom DNS addresses under Advanced Tab/Setup/Internet, otherwise no.
