TY2's avatar
TY2
Tutor
Apr 28, 2023
Upgrade AC2200 to AXE 11000
Want to upgrade old RBR40 and three RBR20 satellites to the new 960 series. Question I have is about number of satellites for size of house. Have 3200sq ft  L shape house.  The current package was fo...
  • plemans's avatar
    Apr 30, 2023
    Maybe?
    Its hard to 100% say because while the AX system has a little more coverage, it didn't really boost that coverage by adding additional broadcast power. It was done through a little more efficiency. So if you had trouble penetrating the walls/floor before with the old system, you'll still have it a bit with the new.
    So we can't really say 100% that sure you go remove one of the satellites. All we can do is say "maybe".
