Dawng11
Jan 13, 2025Aspirant
Upgrade from old Orbi to RBR850 error
My old Orbi mesh system stopped working and I got a new one and during the setup process, I’m getting an error message “Orbi Not Found It looks like you might be connected to your old Wi-Fi gateway. ...
CrimpOn
Jan 13, 2025Guru - Experienced User
This description appears to be inconsistent.
- If the old Orbi stopped working, how was it possible to reset it?
(That would seem to imply that the old Orbi was "working".) - When a user sets up a new Orbi system using the Orbi 'app', the first step is to connect the smart phone to the new system WiFi before opening the 'app'. Is this what was done?
To be honest, I much prefer configuring a new WiFi system using a computer connected to one of the Ethernet ports rather than the Orbi 'app'. Is there a desktop or laptop computer that can be connected to the new system?
- Dawng11Jan 14, 2025Aspirant
I reset with the button on the back to clear out any settings. I did try (multiple times) to set it up via the app and it provided me this error each time
- FURRYe38Jan 14, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry setting up with a PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
